Kiri Robbie Posted December 10, 2020 Share Posted December 10, 2020 What clearance do you allow for the pile diameter compared to the steel reinforcing clearance? How parallel and straight are deep pile holes? Link to comment Share on other sites More sharing options...
Martin Larisch Posted December 20, 2020 Share Posted December 20, 2020 If you refer to the concrete cover zone for bored piles, they depend on your exposure class (how aggressive is your ground and ground water). Typically, cover zones are 50mm to 75mm for bored piles. Plane installation tolerances are 75mm for onshore piles with cut-off levels within 2m below ground level. Vertical tolerances of 1 (H) in 100 (V) should be the industry standard for modern piling rigs. Reinforcement cages are normally parallel to the pile excavation. If the pile was installed at a very mild inclination of 1 in 100, the reinforcement would follow the same inclination as the cage is always parallel to the drilled hole. Consideration of pile installation tolerances is critical for piled walls (e.g. secant piled walls) and for the assessment of additional bending moments from eccentricities. Link to comment Share on other sites More sharing options...
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new accountSign in
Already have an account? Sign in here.
Sign In Now
