Kiri Robbie Posted February 4, 2021 Share Posted February 4, 2021 Any comments on assessment of dynamic loads and protection from unexpected loads such as temporary storage of equipment and materials on the temporary works structure? Link to comment Share on other sites More sharing options...
Barnabas Ilko Posted February 6, 2021 Share Posted February 6, 2021 I am a little bit confused by the unexpected loads such as temporary storage comment. I assume the question might be related to impact loading on structures from vehicular traffic, load being dropped from floors above if no protection fans are installed below, loads dislodging while lifting with tower crane. Or a usual item we debate which is loading on overhead protections from vertical and lateral loads. In case you are after loads falling on a temporary structure, AS1170.1 should be used as a first step. The commentary will explain how to calculate these forces, simple physics. In case you are after storage and impact loads on falsework, please refer to the Concrete Institute of Australia's practice note Z36 which has a very good explanation of how these loads should be calculated. Link to comment Share on other sites More sharing options...
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new accountSign in
Already have an account? Sign in here.
Sign In Now
